95 xh12 heat
Guest
Posts: n/a
95 xh12 heat
I have no hot water going into the cabin heater core. I have hot water to the solonoid valve that I assume regulates flow to the core, but the opposite side is cold. Is there a fuse or a simple fix for this? Has anyone else heard of or had this problem. I was thinking of bypassing it but would rather fix it prpoer if economical. Thanks for any response in advance.
