96 jag xj6 power loss problem/electric drain
Hey so I have a 96 xj6, the engine runs strong, 178,000 miles & my problem that im dealing with is i have a good tested alternator, & battery, but im having a drain of some sort in the car. If my battery is fully charged itll start my car perfect but while driving you see the gauge dropping and power loss happens, battery only holds power for a good 15mins. Is there a relay that I can purchase before I get a mechanic out to check my electrical? If you have had any these problems please route me to a better position.
Received 9,440 Likes
Um, I know it's confusing since they put the Xj6 badge on the trunk and all, but I don't think your car is "one of ours."
This section is for the Series 1, 2, 3 Xj6s, built from 1968 to around 1989 or so.
You might more help of you look here:
https://www.jaguarforums.com/forum/xj-xj6-xjr6-x300-26/
