96 xj6
Actually being a 96 that would be the X300 forum he needs to visit. That said initial diagnosis would be the same no matter for me and that would be is power being sent to the starter? If not leave the ignition on and jump the starter, does the car start and run? Obviously if the starter is getting juice but not doing anything it's dead. If it isn't but starts and runs fine when you jump the starter I'd start my search at the ignition switch/starter relay/howeverthehelltheypowerthestarterinthatparticularc ar. If it isn't sending power and the car wont run when cranked over by jumping the starter that's where the fun begins.
![Icon Cool](https://www.jaguarforums.com/forum/images/smilies/icon_cool.gif)
Edit: realized you just replaced the battery, too. Ground terminal good, clean and secured on both ends?
Received 10,863 Likes
Turn the key "on" and take a peek at the gearshift indicator. Is the "P" glowing red? If not, wiggle the gearshift around and back/forth until it does. Then try starting again
Thanks everyone....I jumped the starter, and got the girl running. Let run for about 15 min. Thanks.
baskervillema
10-01-2015 06:43 PM
FS[MidAtlantic]: 1997 XJ6 VDP $3,900 - Very RARE Anthracite on Warm Charcoal
42Ajd
09-26-2015 07:04 PM
