Ac is giving me fits!!!
So here I am in Florida, driving along on the surface of the sun, and ac doesn’t want to play nice!!!
turn ac on, everything whirs and clicks, comes on blowing hard, lots of ice cold air,,, then after about 3 minutes, makes another whir and fans stop, they don’t slow down, they stop, fiddle with the switches, clicking from auto to hit, to low, back to auto, nothing happening, spin the temp selector around to 85, it whirs , back to 65 whirs again, so this a few times, it all comes back on, but only for a few minutes then shuts down again, compressor never kicks off!
get it home and start trying to troubleshoot per the jag ac book, and of course everything wants to work now, so go drive around block and now it shuts down again, I switch to defrost ( as it seems to me like a fan issue) as that’s supposed to through fans into high speed, alas no fans at all when I try, all the whirring and clicking behind dash but no air blows out the defrost vents( or anywhere) cannot hear fans running at all!!!
what can I test / try next without dismantling half the dash, getting ready to move in 3 weeks, cannot have two cars undrivable!!
remove the black floor plastic vent next to the right knee driver side, remove panel and there it is, a black large relay with a bunch of wires connected to it. The center wire is screwed to the center spade terminal, this wire becomes loose sometimes.
shop manual sections in my website, download free or view online:
https://jagupgrades.yourwebsitespace.com/
Mkii250 (07-10-2023)
Hi Darren,
Before worrying about that relay, I'd look to clean and brighten up the Grounds for the AC system. I had ton of problems with my AC Fans at one point and took apart and reassembled the microswitches piles of time only to find that the seemingly very clear ground points had some unnoticeable oxidation. Cleaned them up and it worked brilliantly and has done now for two years. Try the easy stuff first! The grounding points are listed in the wiring diagrams. The bad one for me turned out to be the one up under the dash pad accessed from the passenger side footwell.
FWIW, I'd doubt the relays are the issue because the fans are actually coming on, just intermittently.
Hi Darren,
@Darren: You are not alone. My AC stopped working on low speed. I believe I have a couple of spare microswitches if I have to go that route. The relay Jose mentioned is located behind the left hand cheek panel. I have to check that relay also. I agree with Muttony that you should check all the ground points related to the AC system.
My car is also lumped and I recently had to pull the engine to replace the freeze(expansion) plugs. In the process I damaged the AC Condenser. I ordered one from AC SOLUTIONS in Texas and it should be here around May 9th. Once I get that installed, I will address the blower speed issue. I had issues with the blower speed about 4 years ago and the problem was with the microswitches. Next week I will be rummaging through my garage and shed to locate the microswitches. I also have a spare relay and blower motors.
If you end up needing any of the items I have feel free to reach out to me.
The following 2 users liked this post by sanchez:
Darrenmb (05-04-2024),
Greg in France (05-05-2024)
aacpa15215
05-17-2018 09:26 PM
