ac/heater used to never shut off, now wint come o
Old 03-14-2020, 02:54 PM
kirkyboy's Avatar
Default ac/heater used to never shut off, now wint come o
Hello,
First, Id like to say thanks to anyone who can guide me a bit with my problem, This site has a lot of knowledgeable people.
I have had my 1984 xjs for few years, and the ac/heater never shut off. Temp control and airflow were adjustable and seem to work, but it would always be on low, just couldn't turn it off. It wont c ome on, but even in off you can tell the temp. control is working, so it seems its just a flow problem. I couldn't find any posts that addressed the 'WONT SHUT OFF" part, so I has hoping you had possibly seen this ocurance, or if they have anything to do with each other. please bestow all of your wisdom of the air condition system.
Thanks for your help!
Old 03-14-2020, 03:09 PM
Jose's Avatar
Received 2,482 Likes on 1,865 Posts
do you mean the Fan or Fans will not go off?
it sounds like the On-Off "mode" switch was going bad and now is dead.
the "mode" switch is the one with the Off-Low-Auto-High-Defrost positions.
Old 03-14-2020, 03:42 PM
kirkyboy's Avatar
you said it more correct than I did. originally the fans wound just keep blowing, and you could adjust the lo/hi amount, it just would not shut off, so I suppose that's the fsns not shutting off. see what you are getting at with the switch, but this car has a v8 conversion, and I wasn't sure if there is a fuse before the fan/fans, or something like that in common with both problems.
BTW, I have four fuses in the car that are just there, they look to be original, but if here is a fuse that shuts off the fans, so they didn't burn up or something. please let me know. if you tell me there is nothing, ill dig into the switch and wiring. thanks for getting back so quick
Old 03-14-2020, 03:48 PM
Jose's Avatar
a blown fuse would turn OFF the fans and if not replaced, the fans would not come ON.
try the S57 wiring diagram, download it free at my website:
Jag Upgrades Home
if that does not help you, try this website:
www.jag-aire.com
Old 03-14-2020, 03:58 PM
kirkyboy's Avatar
right, that's what happening now, originally, I always had airflow, couldn't shut it off. now, I have no airflow In any mode, now, it could be a fuse, I just didn't know if there was anything to link both problems, and since these fuses aren't labelled, I was hoping to find that one of them could be causing problems. I wouldn't think the fuse would have been the culprit originally, I was searching for something that would be common for both problems.
Old 03-14-2020, 04:04 PM
Jose's Avatar
the fans not shutting off could be a bad switch or a misconnected switch.
The fans not coming on could be a blown fuse or a dead switch.
Difficult to diagnose without substituting the switch or looking for a blown fuse.
what year is the XJ-S ?
Old 03-14-2020, 04:07 PM
kirkyboy's Avatar
1985. I made sure all the fuses that installed are good regardless of where they go.
Old 03-14-2020, 04:14 PM
kirkyboy's Avatar
you da man, jose!. this will get me where I need to be
Jose (03-14-2020)
Old 03-14-2020, 04:20 PM
Jose's Avatar
excellent! I have other documents there that you can download about the Delanair a/c system.
Robbo9
03-05-2020 08:55 PM
JagDE45
08-27-2019 12:36 PM
OnebadassXJR
07-31-2019 09:06 AM
S-TypeNOR
11-28-2011 10:08 PM
Brutal
03-26-2009 10:20 PM
Quick Reply: ac/heater used to never shut off, now wint come o
