AC leaks
AC leaks
Using a freon leak detector to find some freon leaks on my 82 XJ6. Found one at the receiver drier Easy repair
But my detector is screeching at the rear of the compressor. I know there is 2 o rings where the hoses connect. Are these available? Part number?
Also it appears I may have a leak at the pressure relief valve screwed into the backplate These seem to be NLA.. Anyone had a leak in this part and can they be cleaned or repaired.
Received 10,989 Likes
The GM number is 2724674
Bit there are lots on online vendors....
Hy-Capacity Suction & Discharge O-Ring A6 & R4 Compressor - 88415
GM / Ford Suction Discharge Manifold O-Rings CP0026-2
Or you can buy an AC O-ring assortment kit at any auto parts store
Jag7651 (05-31-2017)
