AC pump replacement
The AC pump replacement continues apace. I'm moving the temperature/pressure sensor from the Harrison to the new pump, and it seems there's a part incompatibility. Can the old seat be moved to the new pump, or does the sensor need to be a different part?
Sensor<br/>
New seat
Old seat
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1120x2000/1440860129435_1287407427_f25a6c5c68404fb349e9e66b860993f10783fa56.jpg)
Sensor<br/>
![](https://cimg7.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1120x2000/img_20150829_104817_8632708fb541b750a6e5821024a91e91ba5bdd4e.jpg)
New seat
![](https://cimg9.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1120x2000/img_20150829_104858_c2d8066437e755ec07de224fa41c90abb8e26607.jpg)
Old seat
Received 10,867 Likes
Hmmmm.
I suspect you're running into the 'superheat switch' versus 'HSLP switch' dilemma.
The two are not interchangeable
I'm betting you are trying to put a superheat switch into the hole that was intended for an HSLP switch. The attached illustration might be useful
The 'seat' is the rear plate of the compressor. I wouldn't want to disassemble the compressor as it would surely void the warranty
Disregard those numbers!
Those numbers are for the compressors, not the switches
Sorry
Sorry
KarimPA
09-03-2015 07:32 PM
