Adding foglights and trying to use the existing headlight switch (US Spec Series 2)
I know the trick to doing this on the series 3 (The knob pulls off, you remove the c clip, then the switch can be depressed and rotated to the final position) but how do you modify a series 2 switch?
I am guessing its the same principal because the switch does have a "fog" position, and the wires are there taped up beside the radiator.
I have tried to pull the knob off, but it felt pretty secured on there. I read somewhere about there being a button you had to press on the shaft that would allow it to release, but I looked everywhere when I had the whole dash out recently and I couldnt see anything.
Any inputs welcomed
Any inputs welcomed
Sarc (05-24-2016)
Roger Mabry
04-11-2016 07:38 PM
Eel
04-05-2016 05:25 PM
Dale Konkol
03-31-2016 02:40 PM
