adventures in air conditioning
I finally got around to pulling the leaky evaporator out of Blue Six this week. A good as tested evaporator from another Delanair unit was to be the transplant - lo and behold; the gods of planned obsolescence have reared their hideous, pustule-covered heads again. The transplant, apparently out of a SII car, has flare fittings for the expansion valve whereas the SIII unit uses what appears to be an SAE fitting with o-rings. The compressor kit I bought (supposedly for a SIII) came with an expansion valve with the flare ends and I ended up sourcing the correct valve from another vendor. I point this out because there seems to be some variation among vendors as to which part fits which car - if you can't see a picture of the actual part you need buy from someone else.
The unit from Blue Six has a tear in the copper pipe just between the ell for the return hose and the expansion valve capillary fitting.
A repair attempt had been made by someone before me as it was evident the a/c unit had been out before. I brazed copper tubing for a number of years occupationally so I should be able to repair it (the original repair was soldered). Of course there will be members who will cry "just buy a new evaporator!" They are 450 bucks and I had to buy a new fridge for the house last week. Repair it is, and I can pressure test it before it goes in.
On taking the dash apart I found one of the more creative DPO repairs I've seen. Someone cut the opticell cable to the lighting switch and attempted to splice it with copper wire.
The following 7 users liked this post by metalbasher:
Grant Francis (08-06-2020),
Greg in France (08-08-2020),
JagCad (08-08-2020),
Jahmiata (08-09-2020),
LnrB (08-07-2020),
and 2 others liked this post.
Hi Ken,
if you can't fix your evaporator let me know, I'm not too far away ( Dallas ) and have two Series 3 parts cars. I bought them non-running so I don't know the condition of either AC system though.
Trying to splice fiber optic with copper wire reminds me of a landscaper back when I did utility marking,
he decided to install irrigation etc at the entrance to a new subdivision WITHOUT calling in a dig / locate ticket ( free ! ).
I was en-route to other jobs and caught him. He had already chopped the brand new composite fiber ( power copper + fiber ) and was deep trenching like #*** on the other side that had a 2" gas main & primary power !
He said he could splice the line back with quick connect beans ! Told him, don't think so it's fiber optic !
Cheers,
Brian
Cheers,
Brian
Received 9,472 Likes
The following 3 users liked this post by LnrB:
Once I cleaned up the damaged area it took five minutes to braze the repair (brazing alloy and solder hate each other). The A/C unit is back in the car and reassembly has commenced. Hopefully I can avoid Shipwright's Disease and get it finished without it turning into a major project (I have enough of those already). Everyone knows how that is - while I'm in there I might as well take care of this... and this... and that...
Am planning on dragging a '73 SI XJ rescue (project) home in a few weeks - the wife thinks I've lost my mind.
repaired outlet - not the prettiest but it won't leak.
Jahmiata (08-10-2020)
Speaking of complicated, I'm trying to decipher some more of the creative wiring the DPO performed. There is a large, flat earth strap under the console - one end terminates to a stud on the transmission tunnel. The other end has been taped up. Any idea where this other end goes? My searches have turned up nothing.
Received 10,989 Likes
Believe it or not that giant ground strap is for the radio
Thanks for that, Doug. A strap that size could earth a tube-type wireless R/T from the Forties!
Bill, I am planning on using R-134A - my earlier '85 XJ was converted, too. The A/C might not have been as cool as R-12 but in this part of the country it was more than adequate. I'll let everyone know how it goes.
yachtmanbuttson (08-12-2020)
Chuck Schexnayder
12-04-2018 07:09 PM
