Aging oil
I have a 1977 XJ6C, which sees less than 1500 miles use per year. It gets a 20-30 mile drive every month at least, to keep the gaskets intact (and for sheer enjoyment). I use Mobil One 5W30, which, needless to say, looks perfectly clean after a year and a half in the engine. Is there any need to change the oil based purely on the time it has been in the engine?
________
1999 XJR
________
1999 XJR
Received 6,330 Likes
If you get it out every month and get it up to temp and run it for 30+ minutes at steady speeds, you will burn off the vast majority of condensation and fuel from start-up. As long as the carbs are in a good state of tune and not running pig rich I would have no issues with 2 years...I'm assuming the car is kept indoors in a climate controlled environment.
