Air Conditioning
you need to make sure what type of refrigerant you have in the system, many of these cars have been converted to R134a, you don't want to mix refrigerants, it's potentially dangerous and it will ruin the a/c system components.
if you don't know what refrigerant is in the system, take it to a a/c shop to find out.
If you're in the US then R12 is difficult and very expensive to come by. I just converted mine when putting the AC back in service. I changed the expansion valve, receiver/drier, drained the oil, flushed the system and refilled with PAG oil and R134. Working pretty damn well, this isn't the first car I've converted, either. No, it's not as cold as R12 but it's cheap and easy to find, don't let the conversion horror stories scare you. If you find after re-charging that you have a leak that needs to be fixed and have to re-charge again and you're using r12 then God help your wallet.
![Icon Biggrin](https://www.jaguarforums.com/forum/images/smilies/icon_biggrin.gif)
If you're in the US then R12 is difficult and very expensive to come by. I just converted mine when putting the AC back in service. I changed the expansion valve, receiver/drier, drained the oil, flushed the system and refilled with PAG oil and R134. Working pretty damn well, this isn't the first car I've converted, either. No, it's not as cold as R12 but it's cheap and easy to find, don't let the conversion horror stories scare you. If you find after re-charging that you have a leak that needs to be fixed and have to re-charge again and you're using r12 then God help your wallet. ![Icon Biggrin](https://www.jaguarforums.com/forum/images/smilies/icon_biggrin.gif)
xjrjag
09-27-2015 01:53 AM
Guy-Pierre Boucher
09-16-2015 05:55 PM
FS[SouthEast]: 2006 and 2007 Jaguar Media Press Kits
SCMike
09-09-2015 09:30 AM
