air conditioning layout
OK I have a 1986 xj6. I have been working on this car for a couple years know on and off. I want to put the ac back in but i think I might have misplaced a piece. Does anyone have a drawing or layout or something to show me what I need. I know this sounds funny but I just don't remember having an accumulator in this system. I have a long tube that is attached to the bottom of the condenser...is that what they used as an accumulator/dryer?? Any help is greatly appreciated.
This website is good for parts schematics
Condenser and Receiver Drier - Parts For Series III Saloon | Jaguar Heritage Parts UK
Bottom tube is trans cooler
Received 10,978 Likes
The accumulator/drier on your '86 should be attached to the radiator upper mounting panel, mounted horizontally. Some earlier models had a vertical mounting arrangement, however.
The lower tube you mention does sounds like the trans cooler. Are the two lower radiator hoses attached to it? if so, it's definitely the trans cooler.
If not, please post a picture
This illustration shows the trans cooler arrangement, item #3
Radiator and Hoses-From (V)200747 - Parts For Daimler Limousine | Jaguar Classic Parts UK
Doug thanks for the reply. Its defiantly the drier on mine it is actually hard line right into the ac condenser and it is mounted right at the bottom. It does look like that trans cooler but it is defiantly not it. Maybe someone along the way has put in a different one than what the car came with in 86. IDK
Cadwallader
09-14-2016 06:23 PM
