Air conditioning - XJ6 series Ii
Hello there - I am the world of Jaguars and even newer to this forum. I have done the intro post and as promised I have a couple of questions that I seek some help on please
My new Jag does not have air but it does have the in dash temperature controls so it must have had it at some time. XJ6 Series II 1973 SWB 6 cyl
A local chap is dismantling a 1997 X300 LWB straight 6.
My question is can I swap all the under bonnet (hood) mechanical gear - compressor, mounts, condenser and what ever else - my girl has none of the gear.
Appreciate your response.
Received 10,988 Likes
Try contacting David Boger at https://everydayxj.com/Used-Jaguar-Parts.php
He may be able to help directly or point you in a good direction.
No, none of the 1997 items will work for you. You are looking for parts up to 1986 for the XJ6, and some parts up to 1992 on a V12 car. XJS parts will work, such as the interior parts and the compressor, but the compressor mount is different between a 6 cylinder and V12.
That being said, you can get retofit parts that will perform better, such as the compressor and the condensor.
zedtt
10-28-2021 06:47 AM
