Aircon compressor removal
Received 10,871 Likes
Not remove, just shift aside a bit.
There are four bolts holding the compressor. Two front, two rear. The fronts are often buried under caked-on gunk. The rears require that the cruise control servo be partially removed: unbolted a shifted aside
With the four bolts removed just tilt the rear of the compressor upward a few inches to give access to the front plugs. I use s small block of wood as a prop to hold it in place
NathanDD6 (02-23-2016)
beady
02-27-2016 11:45 AM
