AJ6 engine into XJC ( XJ6 series 2 )
Old 06-11-2016 | 09:30 AM
JagCad's Avatar
Jim G.
Really nice work. Cars did just fine sans "resonators", aka "rear mufflers".
Mine has a pair of smallish glass packs welded in a by a PO! Sounded fine as a 4.2. Even better with the LT1!
As the manifold has two outlets, that would seem to be perfect for a true
dual system. No "Y" pipe needed.
Back in the day, six banger cars with true duals droned a bit and "back rapped". Kids of the day liked that.
My 69 Toyota FJ40 4x4 with a 258 CI six sounded great on 6 into 1 headers and a single pipe with a largish glass pack, With other tinkering, it ran great as well. Mix and match upped the CR!!! Ooops, premium fuel needed...
Carl
  #42
Old 06-11-2016 | 01:38 PM
anjum's Avatar
Originally Posted by Sarc
@Jim G
Yes, in out XJ12C restoration we found exactly the same thing, ie the coupe over axle pipes are bespoke and nothing else Jaguar will fit directly. And of course the pipes are unobtainium. Front pipes before the middle boxes are also no longer available.
That's a surprising bit of information!! I was always under the impression that the coupe was the same as the series 1 or the short wheelbase series 2.
All the sites I look at quote the same exhausts, so I'm getting a bit worried!!!!
The rear suspension is identical so what's different about the chassis that causes this problem?
I've got a xj6 coupe and a stainless steel exhaust from a four door xj6 but it will be a while before I can compare them.
  #43
Old 06-12-2016 | 04:34 AM
Jim G's Avatar
Yes I thought that, also I read that the XJC was used as a basis for the XJS.
I think my main problem was that the exhausts are further apart on the XJS where they go under the boot, but even allowing for that they were just completely wrong, even the pick ups on the suspension frame where completely different and in a different place. Having said that I cannot see why the Series 1 should be any different as its the same floor pan ?
  #44
Old 11-20-2016 | 08:19 PM
Larry Louton's Avatar
Hello Jim, I thought you told me you were going to come over to Florida in the fall. What happened? My car is up and running pretty good. I was hoping you could drive it for the inspiration to finish. Larry Louton
  #45
Old 11-22-2016 | 08:25 AM
Jim G's Avatar
Default Visit to Florida
Hi Larry
Yes I am here , in Tarpon Springs, I would love to see your car.
we are renting a house until the 9th December, the phone number here is 727 943 2138
I would drive down to you any time !
  #46
Old 12-11-2016 | 06:59 PM
Default Hope you had a good time in Florida.
Here is that photo of the oil pressure gauge, switch finally. It fits on the block kind of funky but it fits, Got the front seat cushion covers back from Houston.
Fits pretty good, So I took the back seat all apart to have those done. Photo's to you when done. I think I'm going to move the passenger seat back a bit to.
Best I could do while handling camera with one hand
  #47
Old 12-12-2016 | 04:36 AM
Jim G's Avatar
Default Oil Switch
Yes had a great time thanks Larry, bloody cold here in UK.
I see what you mean about the 'tee' piece, I will make one up before I refit the engine ( in the spring)
jim
  #48
Old 12-12-2016 | 07:02 PM
You don't have to make one, Take it off a series 3 engine. The banjo bolt and sealing washers fit right on. Larry
  #49
Old 12-17-2016 | 11:48 AM
slofut's Avatar
Originally Posted by Jim G
Which wheels ?<br/><br/><br/>I am fortunate enough to have a set of XJR6 an a set of XJR8 wheels ( my road car being scrapped ) <br/><br/>Which ones do you think, I fancy the rear ones in black, the car is Green, no bumpers yet but fancy black ones
Jim, I vote for the front wheels. I have xjs Aero 11 slots on my car, I think they look very cool.
  #50
Old 12-17-2016 | 11:57 AM
slofut's Avatar
Here's an old pic...
and an even older one
  #51
Old 12-18-2016 | 05:00 AM
Jim G's Avatar
Default Wheels,
They do look really good ! Never thought the XJS ones would suit !
Niiiice XJC by the way !
slofut (12-19-2016)
  #52
Old 12-18-2016 | 09:51 AM
slofut's Avatar
Wider and lighter than orig too. I put 225-60-16's on them. I will say, the difference in ride quality with shorter sidewalls is immediately noticeable, but you soon forget with the improvement in handling.
  #53
Old 07-18-2017 | 09:53 AM
Rustyxjc's Avatar
Great thread!
Rusty
  #54
Old 11-25-2017 | 07:56 AM
Rustyxjc's Avatar
Hello!
I'm going to post this in the "wanted" section as well.
Does anyone have a series 3 Banjo bolt and oil switch fitting? I really need one!
thx. Rusty
  #55
Old 11-26-2017 | 11:43 AM
icsamerica's Avatar
Originally Posted by Rustyxjc
Hello!
thx. Rusty
Why do you need it? I suspect I may need it soon too as my AJ16 to XJC project just started burning gas but I haven't got to gauges yet.
  #56
Old 11-26-2017 | 09:05 PM
Rustyxjc's Avatar
Xactly Trying to find a home for my oil pressure Gauge. I did order an adapter that I think may work. I have been searching for weeks! I'll let you know if it works.
Rusty
  #57
Old 12-01-2017 | 03:54 AM
Rustyxjc's Avatar
Solved!
Titanfittings.com
SS-9035-04-02 1/4" Male BSPP x 1/8" Female NPTF - Stainless
i now have a real home for oil pressure sensor
Rusty
The following 4 users liked this post by Rustyxjc:
Doug (12-02-2017), icsamerica (12-01-2017), olivermarks (04-09-2018), slofut (12-02-2017)
  #58
Old 12-02-2017 | 08:09 AM
slofut's Avatar
Great Link Rusty, thanks!
  #59
Old 04-07-2018 | 09:13 PM
Maxiv's Avatar
Hi Jim,
Hope you have sorted your XJC?
I am currently thinking about getting an old 1976 XJC from abroad as I found a body for 2500£, however this car doesn’t have engine neither gearbox.
Based on your experience, could you kindly advise what car should I buy for a donor?
Unfortunately I am not a mechanic and I won’t be able to fitnit myself so I will need to find someone with skills who could support (ofcourse for a money).
Mamy thanks for any help you can provide,
Martin
QUOTE=Jim G;1417652]Well it took 2 years looking on EBAY... buy I finally found an engine.
I actually managed to get an AJ16 XJR car ( auto) with multiple 'issues' but a 'good ' engine.
I had already found a Getrag 290 so... off I go !
Thinking of using the X300 servo and brake pedal as it has provision for a clutch pedal.
Will the LSD from this car fit the XJC rear axle ?
Going to contact Andy and see if he can sort me an ECU ,try it in the car , then pull it out and fit it in the XJC[/QUOTE]
  #60
Old 04-08-2018 | 06:04 PM
Martin, You might be better off contacting Jim and seeing if his coupe is for sale? Larry
