AJ6 in a series 3
AJ6 in a series 3
I recently bought an incredibly pristine 1985 series 3 XJ6 with an engine problem. I got the cylinder head off and there is quite a bit more damage than I had hoped so the engine will have to come out, at a minimum it will need a head and one piston. I can pick up a complete 1991 XJ40 for $300. Is the AJ6 and 4 speed tranny worth the effort to swap out? I have been a mechanic since 1979 so the actual swap and wiring isn't an issue nor is the rebuild of the original 4.2 . In the end both options will be comparable money and the swap will be quite a bit more work. Part of me would prefer to keep it original but the lighter 24 valve 4.0 and overdrive tranny may be worth the extra work, at least it would still be all Jaguar.
Received 10,989 Likes
Received 6,327 Likes
Doug (08-25-2016)
AW2Jaguar
17
04-06-2016 11:26 AM
FS[SouthWest]: Series I 1973 Jaguar XJ6 driver on BaT Auctions! (in OK)
Ipc838
04-01-2016 10:31 AM
FS[MidWest]: Seen on CL - 1991 XJ40 w/ Manual Trans, Milwaukee
95 AJ16-5
03-31-2016 03:44 PM
12-22-2009 10:38 PM
