Alignment
Received 10,952 Likes
Caster is adjusted at the upper ball joint. The ball joint has shims on either side, six in all. Moving them to the forward position or the aft position changes the caster.
Camber is adjusted at the bolts which hold the upper control arm shaft in place. There are shims behind the bolts. Adding/removing shims moves the upper arm inwards or outwards to change camber
The following 3 users liked this post by Doug:
DC73 (05-19-2015)
