All Electric Windows Dead
Received 10,876 Likes
Is this a Series III DD6?
First thing to check is that the lock-out switch hasn't been inadvertently flipped....as that'll knock out all windows and sunroof simultaneously. The lock-out switch makes/breaks the ground circuit for the window-sunroof relay.
If the switch has been flipped then I'd suspect the relay itself. I can give some EZ tests if you have a test light or meter
Or....
Power Window Circuit Description and Diagnosis
Or....
Yes, it's an on-off switch. Whatever position it is in now, just flip it opposite....and see if your windows come back to life. If not then you probably have a dead relay....which some testing would confirm.
Received 9,227 Likes
Doug (04-20-2018)
Received 2,399 Likes
