All Electric Windows Dead
Old 05-04-2018, 08:56 AM
Flappers's Avatar
I'm not sure it is, it shares 90% of the same numbers on the top of it... Can you see if its compatible?
Regards Sam
Old 05-04-2018, 09:03 AM
Jose's Avatar
Received 2,444 Likes on 1,839 Posts
the round one has 4 or 5 contacts??
Old 05-04-2018, 09:42 AM
Doug's Avatar
Received 10,876 Likes on 7,153 Posts
The two you've shown in the pics are compatible; the little mini-diagram tells the story.
You'll often see relays with five terminals marked 30-85-86-87-87a or sometimes 30-85-86-87-87. Sometimes the little mini-diagram shows a diode or resistor between the terminals. Different relays; different usages, often interchangeable with the four pin relay, sometimes not
But for the purposes of this discussion, yes, those two relays you've shown will interchange
Old 05-04-2018, 11:38 PM
Flappers's Avatar
Sorry Jose, yes they have the same amount of pins. Problem solved, thanks Doug
Regards Sam.
me_laur2004
04-24-2015 11:09 AM
WaterDragon
08-07-2013 06:22 PM
muncher
10-23-2012 04:06 AM
Masterplop
09-10-2010 11:31 AM
Michigan
03-17-2009 04:24 PM
Quick Reply: All Electric Windows Dead
