Alternator NOT Charging - 1985 XJ6
Hi All,
Now my 1985 XJ6 is responding to treatments but the expert mechanic has told me yesterday that the only issue with the car is that the Alternator NOT Charging.
The fire stays well but when the battery terminal is removed, the fire goes off.
Now, what could be the possible issue of the alternator not charging and how could this be solved?
Help please.
Mike
Help please.
Mike
Received 10,867 Likes
Sue'sJag (11-24-2018)
Received 2,399 Likes
Mike:
UGH, my computer and this webb site do not agree, I lose posts.
That mechanic is no expert. I'll not use the terms I'm thinking.
Running the engine sans battery is a good way to ruin an alternator.
Where is hos meter? Just measure battery voltage with engine not running. Start it. measure again. It should be greater with the engine running circa 13 volts or so, and at rest circa 12 v?
Carl
Carl
Mike,
you will need to remove the alternator and have it tested in a alternator-testing machine. if no testing machine is available, substitution with a new alternator is the only alternative.
Does the battery warning light stay ON?
tbere is a warning light between the speedometer and the tachometer. It comes ON when there is a problem. It has a "battery" symbol and it lights up Red.
The external wiring often fails due to age and engine heat. Connections often become loose or dirty. Usually determining this is a simple matter of visual inspection although testing with a meter is sometimes better.
If wires are faulty they can repaired....or replaced. Connections can be cleaned and tightened and/or metallic terminals replaced.
My 2005 Jaguar xj8 has worked flawlessly though I rarely drive it. This morning I started it and it was not charging. I always keep it on a battery tender, so it fired right up. Thank you for pointing out that this electrical system is nothing magic. I feel like I might have some rodent damage because it is not driven.
I was referring to the older models typically discussed in this section. I can't promise that the charging system on your '05 model is as simple.
philjoemill (12-08-2018)
patpin
08-05-2018 01:20 PM
sanchez
07-15-2018 09:38 AM
vdpnyc
02-22-2017 05:00 PM
terrylcook
05-20-2016 03:29 PM
guyslp
12-25-2013 02:50 PM
