another niggley thing
I have this problem with the boot latch.
It seems the noise I have heard on occasion was the boot lid rattling around because the latch needed an adjustment.
So on my 86 S3 there are 2 bolts that hold the plate that holds the bottom (attached to inner part of boot) of the hook that the latch is supposed to grab when the boot lid is closed.
Well my 2 bolts just freewheel and I can not get any tension on the clasp that holds this "hook' lower stationary portion.
Has anyone else had this problem? there is no way to get behind the rear valance,, May have to weld it in place unless someone else has a better idea.
Thanks in advance
Thanks in advance
Solved!! Got brave and removed one bolts and saw that it was a alloy bolt - good for nothing !! Found in my pile of junk in garage, 2 nice GM coarse thread panel bolts half a size bigger (10 MM) stuffed it in there and now good to go.
Was ready to remove rear bumper and drill 2 1 inch holes for access....no need now.
Cripes when you use torque to hold something in place best not to use an aluminum bolt.
So false alarm..
So false alarm..
So false alarm..
So false alarm..
Received 2,399 Likes
