Any pitfalls of replacing changeover valve with a tee?
I've soaked my changeover valve as much as possibly on my '87 but it still won't clear.
I've seen people mention replacing this with a tee without issue, if you fill the tanks fast enough (normally) there is no issue. If you wait, they settle and can fill from the same side.
Is there any issue with the return valves? If all that is done is replacing the changeover with a tee, does the fuel returning to just one of the tanks pose any issue as far as overflow?
Received 2,399 Likes
In itself, no. My lump package came with a "T" with the proper sizes to do just that. but, the instructions also warned of a potential issue. If the car is parked on a steep hill with a full "uphill" tanks and a lot in the "down hill" tank, It will overflow the low side. Nearby SF has hills and parking perpendicular to the curb that could present that problem.
I think LnrB's NIX has one way valves before the "T". No issue.
OTH, just get a good used or NOs valve from David Boger at Everydayxj.
Carl
Carl
Received 10,916 Likes
No problem with return valves. Assuming no defect, one of them will always be open so return fuel will always go to *that* tank...but that's OK. It all balances out since the tanks are connected
I ran with a "Tee' before repairing my changeover system and had no problems.
The scenario Carl mentions is worth remembering but in all honestly it never seems to come up as a problem. Either it never materializes as an issue or people remain silent about it.
I think one of the charms of the XJ6 are the twin tanks. For a front seat passenger watching the fuel gauge drop ominously towards "Empty" and then observing the changeover procedure along with the gauge climbing again, is a bit of a thrill! Kind of like switching to a "Reserve" tank on an aircraft. I must confess I love to do just this but am running out of first time passengers!
Heh heh...in the days when I owned MGs the kids loved shifting the gears for me. I'd work the pedals, whichever young 'un was with me would work the gearshift.
Memories
Doug (02-22-2018)
amcdonal86
01-19-2012 04:18 PM
