Anybody done a Saturn alternator upgrade?
Old 02-01-2014, 10:11 PM
krswen's Avatar
Default Anybody done a Saturn alternator upgrade?
I see in some of the MG forums that a Saturn alternator is a bolt-in fit to replace our under-performing Lucas units (although the pulley and electrical plug need to be replaced). Anybody done this conversion on a Series 1 or 2 XJ6?
Ken
Old 02-01-2014, 11:07 PM
rustfreemike's Avatar
Ken
Hi Ken - I've installed a GM CS130D style alternator in my Series 1. The Saturn conversion you mentioned probably used that alternator but there are a bunch of different cases, clock positions etc... It's a good alternative to the Lucas unit because it's easy to get and cheap and also fairly compact. The one in my car fits well but I did have to modify the mount a little and shim with washers so that the belt lines up properly.
Also as you mentioned you have to get a V-belt pulley installed. Some re-manufacturers will install the V-belt pulley for you but they're easy to get either way. The plug does have to be replaced with one for a CS130D (cut one off a GM car at the junkyard) but once it's wired up it functions perfectly. It's self-exciting and self-sensing but there is an output for the light. You should also replace the brown output wires from the original lucas with something more substantial because the CS130D puts out about 105A.
I've been driving the car with this alternator for a couple years and it works great. You will have to get used to the battery gauge staying pegged at 14 volts but that's a good thing
There's really no downside to this conversion. I originally did it because I replaced my power-robbing engine fan with an electric unit.
Here's a link to some pics:
Welcome to Jag-lovers - Members Photo Viewing Page
Let me know if you want any more details about the conversion. I think I can find the exact numbers of the one I used if I look around. I moved since I did this so I gotta do a little digging.
Ahabiam (02-18-2014)
10 XF Premium
10-02-2015 09:22 PM
waynepaulj
10-02-2015 04:05 PM
3lvis
10-01-2015 01:56 PM
CaptainHam
10-01-2015 02:01 AM
Quick Reply: Anybody done a Saturn alternator upgrade?
