Anyone Ever Seen this Video with a Replacement for the series II AC Amp
Very interesting. I'm not an electrical engineer but could more or less follow along with what he was doing. Seems like he just recreated the amp using modern components. But you still have the servo, flaps, etc, etc. Jay Leno has said in several of his videos that they just convert over to Vintage Air systems to get reliable heating and a/c. But as I understand it, you have to do remove the dash and then do major surgery. I'm still looking for a simple to install, reasonably priced replacement. In the, meantime on my 79 I have intalled the manual control switch from Jag-aire along with the simple toggle switches to (1) be able to close off the hot water valve, (2) turn on or off the a/c compressor, and (3) control the fresh air flap. Total control of the system but not automatic temperature control.
Jeff
Jeff
It is interesting. The guy has a webpage thisoldjag.com and has a few Jags of different types, so it appears he knows what he's doing. I don't understand if what he is doing is replacing the amp or something else, (maybe because I don't understand what the amp does very well). It seems the thing he created just maneuvers the doors to make a different air flow combination. Is that all the amp does?
Jsedita74
08-13-2011 08:08 AM
CatDaddy
05-19-2007 05:25 PM
