Backfire set the air filter on fire?
YEP.
Wakes up even the dumbest mechanic real quick.
Ya want to see a V12 light em both up, that is scary.
On the SU engines, it is one of 2 things.
1) The timing is too far advanced.
2) The carbies are set tooooooo lean. VERY common.
The filters rarely ignite that much, usually smolder a tad, but if they are oily mist soaked, or older in age, then Guy Fawkes is going to pay a visit.
I would be resetting the mixtures, richen them a 1/4 turn wil do wonders, balancing the 2 carbies spot on, and check the timing very carefully.
If all that proves fruitless, then lift the inlet camcover, and ensure the inlet camshaft is dialed in correctly, as it could be a few teeth advanced on the micro adjuster, and that could, at a pinch, cause a back fire flame, but that would be a very long way down on any list I had to compile.
Received 2,260 Likes
Received 10,867 Likes
That's right!
Sometimes, though, when firing up cranky engines, I've run out of battery before getting the carb fire fully sucked in, bringing on some tense moments
Received 2,399 Likes
