Backfiring Problem
Backfiring Problem
Hello, My 1982 XJ6 is having some troubles. At some times, it will start normally and I'll drive. However, after a while the RPM will drop and when I press the accelerator it is hesitant and will backfire a few times and eventually return to a normal operation. On some occasions, upon starting the vehicle, it has low RPM and and when I press the accelerator it'l backfire. Anyone have any insight on the matter?
Have the injectors ever been replaced. I would start with their replacement
and at the same time replace the fuel hoses.
It should make a difference in performance.
Walter
