Battery Cut-Out (XJ6 1993)
Does anyone have experience with the "automatic" type of battery disconnect that cuts out the battery when the ignition is "off" and the charge drops to 11.7 volts? Supposedly, then, you turn on an electrical accessory (like the headlamps) and it cuts the battery back in to start the car as normal. Thanks.
rusty37
04-05-2020 07:40 PM
Guy-Pierre Boucher
09-16-2015 05:55 PM
