Best solution to this cracked sump
I’m rebuilding my S3 4.2 (1986 XJ6) and realized kind of late that the sump has a crack that was previously repaired, if you call it that:
What is my best option short of getting a replacement sump here? Get it welded, or will epoxy be sufficient?
Thanks!
Thanks!
The following 3 users liked this post by Jagboi64:
Greg in France (01-14-2024)
Also, there are different types of JB Weld. Make sure the one you are using is for high temperature. 5 minute JB Weld is not the one you would use there. As Andy said you have to heat that area to get the oil out of the crack. If not it will fail eventually. JB Weld does not adhere to oily surfaces.
yachtmanbuttson (01-16-2024)
Received 9,472 Likes
Yes, cleaning was a Nightmare as it was alloy and on the bottom, but I couldn't drive it like it was so had nothing to lose. First item was to scrape off the band-aid cr@p some cheapo shop had slathered on previous to our ownership, which lasted long enough to get it out the door (which it could have been harder to remove had it not already come mostly loose on its own).
I used on it, followed directions, and it Never leaked at that spot again.
Darrenmb
04-12-2020 01:08 PM
