Best u-joint source?
Hello,
I'm the proud new owner of a 1982 XJ6. Amazingly I purchased this Jag not running and, after an ignition switch repair, I'm now driving this all-original 82 daily. Ok, it's only two days but still!
I have what appears to be an early failure stage u-joint on the outer passenger side.
What brand is your recommendation for this part? Best source?
Thanks in advance!
Thanks in advance!
Hey Jig Jag...
I may have a few on hand... And if not, I have a ton of other stuff for your car...
Best part, I'm only about 30 miles North of Charlotte (near Concord)...
Check out my site, or give me a call sometime... (704-796-9902)..
I'd be glad to talk to you about your XJ...
David
shop.everydayxj.com
David
shop.everydayxj.com
Best U-joint source
Northern Drivetrain, LLC
For Spicer U-Joints, I used these folks for my '77 XJ12L u-joints.
I went with "no zerks". U-joints without zerks are stronger. Spicer u-joints are pre-grease with a new synthetic grease. Instructions indicate - do not add grease.
Grease does not get sprayed out of the u-joints from over greasing.
Hey Jig Jag...
David
shop.everydayxj.com
David
shop.everydayxj.com
This is fantastic! I'm glad to see there's a Jag parts source so close by!
I definitely want to come by and check out your operation. I think the U will hold out for a trip up to Concord. In the meantime I'll give you a call. I'd love a chat with someone more knowledgeable!
let me know if you have one available! I'd rather not source from NAPA unless necessary.
Thanks so much!
Paul
davidboger (03-14-2016)
IndelXK8
03-27-2016 08:33 PM
Busa
56
03-14-2016 03:43 AM
