Body Dolly
DOLLY
A simple 2.5 x 2.5 steel square bar with swivel and rigid caster wheels works well on both front and rear. The same dolly can be used on the Mk2, XJ6, and other Jaguar frames.
BILL OF MATERIALS
Dolly construction detail (shown on Mk2 body but works on XJ6, XJ12, etc)
Jaguar frame dolly
Weld on a plate at the end to mount the castor wheels. Rear wheels should be slight larger to enable the frame to remain roughly horizontal without a downward slope.
Front Dolly on XJ6
This dolly can easily transport the frame on a flatbed truck if needed. Also handy for painting the raw frame.
Painted XJ6 frame on dolly
BILL OF MATERIALS
- 2.5 x 2.5 x 60 square steel bar 11 ga (need two)
- 5.5 x 5.0 steel mount plates 7 ga (need four)
- 5 x 2 rigid caster wheels with brake 800 lb capacity with 4 x 4.5 mounting plate and 6.5" height FOR REAR (need two)
- 8 x 2 swivel caster wheels 1100 lb capacity with 4 x 4.5 mounting plate and 9.5" height FOR FRONT (need two)
- fastening hardware: bolts, nuts, washers as required
Jaguar frame dolly
Front Dolly on XJ6
David84XJ6 (01-17-2019)
BurgXK8
08-08-2013 01:44 PM
Roger Mabry
07-25-2013 11:34 AM
jagxkrtoofast
10-11-2011 02:04 PM
