Bolt Pattern
RE: Bolt Pattern
The pattern is 5-on-4.75", just like Camaros, etc. The problem is that the Jag hubs require a large-ish center hole....larger than most.
One time I found some wheels I liked and just had a machine shop bore out the center holes. I gave them a Jag wheel to get the exact measurement
RE: Bolt Pattern
If you have the rims bored out to the jaguar hub size, could you use a jaguar center cap? Visions of Cragar SS or Centerline rims from the '60s with Jag center caps on an XJ-S sound pretty cool... Raise the rear of the XJS and you have yourself an Americanized Brit dragster!
-Michael
-Michael
baskervillema
10-01-2015 07:43 PM
