bonnet adjustment
I just put my bonnet on a couple of weeks ago and I don't see how you could move it closer to the windscreen. Do the two hold-downs fit in their latches, there isn't much lee-way to the fit of those items. Did the bonnet used to fit? Washers between the hinge and mounting pad of the bonnet? I have never paid attention, but maybe the hinges are adjustable where they mount to the body.
Dave
Dave
Maybe this would help
Dave
Dave
This one is a bit tricky. some years and years ago I remember having the same issue and if memory serves me right the way I adjusted the bonnet was as Follows:
1- Loosen hinges and re-tighten to a point where the bonnet can slide up or down with slight friction.
2- Close the bonnet all the way.
3- lift the bonnet up or push down from the front where the hinges are located paying attention not lift it proud of the front wings.
The gap should, now increase or decrease as the bonnet is pushed down or up.
If the above does not achieve the requiered result, then try the following (more work and quite tedious):
1- Adjust the front Bumper and Bonnet Mounts.
2- Repeat step 1 to 3 above.
I have attached a file for the procedure of getting to the Bonnet and Bumper Mounts.
Regards
Omar
Delighted to see our US members discussing bonnets. I'll be back for the follow-up discussion on getting the gap even with the wings.
More than one member having alignment issues made me think there could have been a mid-run change but according to JEPC the P/N is constant AKP464 throughout the production run.
I recently download the Workshop Manual for my F-PACE from TOPIx and was surprised to find it written in a strange mix of US and Queen's English. For example, both hood and bonnet appear apparently used at random.
LT1 jaguar (12-23-2021)
Back in the 1930s many sedans did not have a rear luggage compartment but a big box that looked like a steamer trunk (see below). I’m guessing that is where our word came from. Any ideas where the term “boot” came from?
Interestingly, my 2007 Vanden Plas has a setting where you can choose between “bonnet/ boot” ajar or “hood/trunk” ajar.
The word "boot"(which is commonly used by the English), goes back to 18th century horse-drawn carriages where the coachman sat on a chest, which was used to store, among other things, his boots. This storage space came to be termed as the "boot locker", which soon became the "boot".
In British English car terms, the hood is the soft-top roof of a convertible.
I have a ‘47 Vauxhall and the workshop manual includes a glossary of terms for all these parts which have different names either side of the Atlantic
The following 5 users liked this post by Andy T.:
GGG (12-25-2021),
JagCad (12-24-2021),
LnrB (12-24-2021),
LT1 jaguar (12-23-2021),
yachtmanbuttson (12-24-2021)
