Borg Warner 66 Trans Slipping
Hi Everyone!
My transmission seems to be slipping in reverse only. It will back up ok if on a flat surface but, it will slip if I back up on a slight grade. I checked and tightened the bands which were loose. I also adjusted the ATF level. Car has only 41,000 miles. Just curious if anyone thinks this might be repairable without having to rebuild the whole transmission? I know it is difficult to say without actually seeing the car, etc. I'm just curious what everyone thinks. Thanks!!
