Brake issue....
Brakes work great until yesterday, It is really hot and muggy out while driving. I notice my brake petal needs to be pressed a little more then usual. about 30 mins later the petal sinks even more. about an hour after that i have slim to none brake pressure, and it no longer stops the car it just slows it down. THINKING i checked the fluid, its full. I checked and pumped the brake while in the driveway, nothing no pressure. I check the ground and the hoses, no leaks. I leave it set for about 2hrs come back out to really start invesgiating the problem, and to my surpise i have full brake pressure. When i turn the car on and press the brake pedal i can feel it start to relive the pressure. Someone told me it could be master cyclinder or he told me some sort of vacumm failure. I thought it might be a valve that is going bad letting fluid back in somewhere.
Are you using DOT 4 brake fluid? It sounds like the fluid is getting hot, or even boiling while running. Castrol GT-LMA has a high boiling point, but the Jaguar Super DOT 4 from your Jag dealer is the best-500 degree boiling point.
Others may have better ideas on seals, cylinders, etc as you mentioned that may help you out.
xjrjag
09-24-2015 10:08 PM
