Brake switch
I figured it out! Does it matter if this switch is connected/working if you do/dont use cruise control?
Oh, youve probably guessed im a new owner!! one more question -
Both my indicators work, however, when I put the hazzards/warning lights on only the left side flashes - any idea how to fix this?!
Thanks again
Thanks again
Received 10,989 Likes
Yup, cruise control release switch. If you don't use the cruise control you don't need the switch.....but make sure other drivers know this.
For the hazard lights try exercising the switch numerous times. If the internal contacts are oxidized....they probably are....this exercise will sometimes clean them. Don't get rough with it, though. The switch isn't very robust.
And/or see if you can mange to get some aerosol electric contact cleaner into the innards of the switch
If no luck, post back
Jag7651 (03-20-2021)
Received 2,399 Likes
That cruise control switch is an interesting application. It works opposite the brake light switch. Default is engaged and CC works. Tap the brake pedal and the CC circuit is open. NO CC, no throttle application. A safety feature...
CC is not enabled in my lump. Not a favorite to me. but, that switch is used. Torque converter lock... Opens the TC circuit when the pedal is depressed...
Carl
Carl
