Breather
mystery solved!
doghead08 (07-31-2012)
my mechanic told me it could take him an hour or a day.
im not to worried b/c the one stud broke off at the end, so most of it is hanging out just not enuff for me to cap b/c of the bracket
the other broke in half, with half hanging aroound my neck and the other in the block
ill get it to him eventually. since i dont go back to work until labor day, im going to clean wire connections and work on interior improvements.
i read yesterday that you can isolate the antenna and work it manually with a switch, so i attempted that today and was successful until my radio refused to power up. the power probably came undone as i tried stuffing that sucker back in the slot.
you're welcome!
with the original radio wiring, the antenna goes down whenever you insert a cassette (or CD if correctly wired), it only comes up in Radio-mode. When using a car cover, this can be a problem, but otherwise why bother with a switch? (unless you have a Serius radio subscription).
FS[NorthWest]: XJ8 / XJR 3" Mina Gallery Intake Pipe only (For X308)
xjrjag
10-12-2015 03:16 PM
