Breather
Old 10-18-2012, 03:22 PM
doghead08's Avatar
Default Breather
i hate to bring out memories that ive successfully supressed but i do have a question regarding the breather fiasco i endured over the summer.
i attempted to clean the breather, broke studs, drilled em out and put everything back together with the utmost care.
we just noticed a slight oil leak under the breather casing.
how will i know if the gaskets were compromised?
i didnt use any type of gasket sealant which i know am beginning to regret.
could it be a clogged screen even though i had it off and cleaned it a few months ago?
Old 10-18-2012, 03:34 PM
Doug's Avatar
Received 10,989 Likes on 7,216 Posts
Doubtful that it's actually glogged after such a short period.
Only way to tell if a gasket was injured is by removing the breather.
If the leak isn't too bad I'd live with it. Just wipe it off from time to time. New gaskets and a good gasket sealer would probably fix the problem but that makes more work the next time you go to clean the breather....about every 12 months or so.
doghead08 (10-18-2012)
Old 10-18-2012, 03:47 PM
doghead08's Avatar
thanks doug. ill keep wipin away. if i do notice it getting worse than ill obviously take action and replace the 2 gaskets...and drop some sealer on that sucker.
xjrjag
10-12-2015 03:16 PM
NathanDD6
10-06-2015 11:20 AM
Jässe in Pälkäne
10-02-2015 05:38 AM
Johncy2000
10-02-2015 01:05 AM
rgp
10-01-2015 02:55 AM
Quick Reply: Breather
