Breather Screen Clogged?
Ok, so I've got a massive oil leak, as if there's a stuck pig in the front of my car with oil in its veins! My (american) mechanic suggested it's leaking from the timing cover, and the gasket needed to be replaced. I just ordered one off eBay, only to have someone call me I had left a message with. This man specializes in hard to find/near extinction foreign car parts. He suggests to replace the seals in the breather screen first, because they often become clogged. Anyone else had a similar issue? I'll take any and ALL opinions here, since I know replacing the timing cover gasket is gonna be a SOB...
Thanks a TON!!
Thanks a TON!!
Received 2,399 Likes
Not a bad idea. Follows, do the easies first protocol. Often works.
Yes, excess crankcase pressures can cause seals to leak that often would not.
But, I would've guessed front crank seal before the timing cover.
No idea as to how to do t on the engne in your car, but, your description is apt.
I don't know if your engine has a version of PCV or is merely vented to the atmosphere.
When your car is well warmed up, remove the oil filler cap. A liitle vapor/smoke is OK.
A lot is "blow by". meaning the rings are no longer sealing and some of the combustion pressure is entering the crank case.
Liveable, but needs constant attention to the venting.
Carl
Carl
Received 10,871 Likes
Carl pretty much pegged it.
As to specifics your car has no PCV valve. Just the breather at the front of the cylinder head. This needs to be cleaned every couple years.....along with the associated piping.
Many bad oils leaks have been reduced to a tolerable level by simply cleaning the breather system
It's just a matter of removing the cover, removing and cleaning the screen and pipe, reassemble. Order a couple new gaskets first
cheers
cheers
Okayyyyy.....
What prompted this, Jose?
the Series 3 XJ has many "American" and aftermarket parts, mostly GM parts, like the Saginaw power steering pump, the Delco air pump, the rack & pinion, the check valves, the canister purge valve, the GM power window motors, (I think the sunroof motor might be from GM also), the power brake booster, the transmission, the seat tracks, and who knows what else, like Sensors, brake rotors, etc.
the seat tracks and front-rear seat adjusting mechanisms used in the S3 XJ are still being used today by GM in their cars.
Made in America, whether in Brazil, Canada, or Mexico. (not neccesarily in the USA).
Now most everything is Made in China.
Finbarr1975
09-16-2023 02:52 PM
