British Nuts and Bolts
Does anyone have a good source for nuts and bolts to fit an XJ6 Series I? I am constantly frustrated with not having the right bolt or nut and buying them one at a time from places like SNG Barrat or XKs Unlimited is killing me with shipping. I did buy a kit from an outfit in England but they are all fine thread, no coarse. Barrat has a pack of 100 but those also seem to be all fine. I would appreciate some input and direction.
Thanks.
Thanks.
Sharvey421 (05-06-2019)
I too, take a sample to ACE hardware, mile-away, and also go for the stainless lock nuts. If you get 1/2 dozen of 1/4, 5/16, 3/8 and 7/16 NC thread, you will find it will cover most all routine requirements for a Jaguar. I use the stainless washers too. 5/16 and 7/16 seem to be the most common. I have a XJ6 S3 and have to watch for metrics that have crept in here and there. If you are working on suspension or critical engine points, Grade 5 or even 8 are options.
Rgds David
Rgds David
The following 3 users liked this post by David84XJ6:
The following 13 users liked this post by Grant Francis:
Daf11e (05-07-2019),
Doug (05-07-2019),
Greg in France (10-01-2022),
LnrB (05-07-2019),
LT1 jaguar (05-07-2019),
and 8 others liked this post.
Apart from Lucas electrical items, where there may well be some BA (British Association), threads or even metric, the nuts and bolts will be UNF (United National Fine) or UNC (United National Coarse). The latter are usually found where studs are mounted into aluminium parts like the cylinder head, (UNC one end and UNF at the other). I don't think there are any Whitworth or BSF threads in the XJs.
The following 4 users liked this post by Fraser Mitchell:
I found these to be helpful:
https://www.nutty.com/
https://www.boltdepot.com/
https://www.warrenfasteningssouth.com/
Grant Francis (05-07-2019)
Try BA Bolts. They have everything. Especially the BA threads for SU's.
As Grant says, we can source most stuff at local bolt shops, but nuts & bolts for the SU's are hard to find.
https://www.ba-bolts.co.uk/
The following 3 users liked this post by o1xjr:
Yup! With UNF being most prevalent throughout the car.
Some of the brake hydraulics are metric.
The only truly oddball size/thread I've comes across is the firewall "+" junction posts. And, I'll wager those were supplied by Lucas, as you mention.
The following 5 users liked this post by Doug:
Grant Francis (05-07-2019),
o1xjr (05-07-2019),
Sharvey421 (05-07-2019)
When needed, I found replacements at the local Ace hardware. An impressive selection of fasteners. And some of the guys there get it. others, not so much. I usually have a guide. A nut that needs a bolt or a bolt that needs a nut !!
I've two Whitworth "spanners". Only used once or twice !! The bolts on the drive shaft!!!
Many decades ago, I swapped in a used transaxle in a 56 VW beetle. All metric . I had no metric tools at all !! Some SAE "close". those plus Crescent and Vice got it in !!!
Carl
Carl
When I had my Series 3 the workshop manual brakes section contained a specific warning about metric fittings. At this time there was a transition in progress in the brake manufacturers from Imperial to Metric sizes On some of the connection fittings, a metric nut would "fit" but really didn't and with the pressures involved when brakes are applied, it could burst off leaving one with no brakes. A mark was applied to metric fittings for a while so one could tell them apart from imperial, but I can't remember what it was, it's too long ago, (late 80a)
albany fasteners
Adding
Albany fasteners as a recommended supplier
Since I like oddball vehicles I rely heavily on using good thread checkers so I know exactly what I am looking for
Finding good comprehensive nut and bolt checkers is half the battle so you can subsequently order what you need online and know they will fit when they arrive...
yachtmanbuttson (05-10-2019)
This made me laugh out loud! Excellent!!
The following 4 users liked this post by olivermarks:
Grant Francis (05-08-2019)
Jaguar made the changeover from British BSF/Whitworth to SAE NF/NC with the introduction of the MK7.
They had the American market firmly in their sights and were very aware of complaints about tooling. The old MK5 was a pain to work on if you didn't have BSF/Whitworth spanners etc.
I am not sure if or when that also applied to the XK120.
I recently had to buy a set of metric pipe spanners to change the flexible brake hoses in my S3XJ6
Dammed nuisance!
Dammed nuisance!
yachtmanbuttson (10-20-2023)
I order from these guys. Really helpful and terrific service. Highly recommended.
https://www.wrightsautosupplies.co.uk/
Alexander Gurney (12-21-2023)
The following 2 users liked this post by Jose:
ukborn (12-14-2023),
yachtmanbuttson (10-21-2023)
