A/c Amplifier
If you have the temp selector set to heat and you still have air coming from the center vents, it's absolutely not working properly, heat is not supposed to come from the center vents. In heat position, the levers on the servo unit at all the way up and heat is delivered through the side
Vents and floor vents. These amplifiers and their relays, especially the relay that switches from heat to cold, are prone to failure. Try hitting the amp on the end opposite the relays with a hammer. Hold the amp with the large flat side in your hand, that would also be the bottom of the amp. Hit the amp with the hammer on the small end striking toward the relays. I have seen three amps start working properly when this is done. Also the small blue pot. That is accessible , move that control back am forth to ensure that it has contact. When then temp control is on the 75 degree position, it adjusts the air to allow to make the system accurate to having 75 degree cabin temp. Also be absolutely certain that the ground for the amplifier is good. And those inline diodes, if they fail, the servos will not respond properly. That's about clears it up!! As far as
My experience goes. Lol. Paul
level 1 (03-01-2018)
Received 10,876 Likes
Brian,
I have 4 used Amps in a box I'd be willing to send up to you from Ontario. I don't know if they work. You could try them and see. Advise is to leave the old one in place, just plug in a new one (ground too), and if it works, stuff in under the cheek panel and don't attempt to replace it in the same spot as original.
$25 plus post for any you keep. Mail back the rest.
Good luck,
Rob
Good luck,
Rob
Brian,
Good luck,
Rob
Good luck,
Rob
#33
#34
must be the Expansion Valve you are looking for? you can see it in the engine bay, behind the engine, at the center, sticking out through the firewall. They do tend to freeze the matrix if out of calibration. If you do not know the history of the Expansion Valve in your car, replace it, it is a GM part.
otherwise I have one amplifier from a 1986 XJ-S V12 Coupe. But I do not wish to interfere with those who have already offered amps to you.
#35
I think what you're looking for is the Ranco Thermostat, under the dash, RH side of the main climate control casing. it has a capillary tube to the evaporator and will cut the compressor circuit if the evap core ices up. That's the only provision/method of compressor cycling.
You also have a superheat switch and fuse at the compressor which provide protection to the compressor....but that'll cut the circuit outright; no cycling function
#36
#37
#38
