A/C hose routing
A/C hose routing
I can't find my file/copy of A/C hose routing. I have the engine and a dummy transmission in the car now and am working through a "dress rehearsal" while waiting for the real trans. I have all the parts for the system, just not sure which hose goes where. If someone has any kind of diagram that would help me, I would appreciate a copy.
Dave
Dave
Dave, what condenser and dryer/ accumulattor are you running? I used the camaro setup that attached to front of camaro radiator, i used . The camaro line to attach to accumulator, and the camaro compressor manifold lines to attach directly to condenser as well, then had custom lines made that confront accumulate to expansion block and from compressor manifold lines to expansion block, , I will try to get some pics, but not sure they will show up well!
To add to what I did, I will say, it’s not perfect and I am redoing the low side line to add a port to tie in a low pressure switch, I currently have zero safety measures if I have a leak, no matter what I try, I cannot make the system work when using the camaro pcm, so it is bypassed and running straight through jag controls!
My installation is with the Johnscars kit. It mimics the original Jaguar arrangement.
Except, of course, the LT1 compressor.
Not too happy with it. The lies run along the lower part of the right wing wall !!! interfere with the heater hoses. ports not easily accessed. Power to the compressor not attached. The system is not vacum tested nor charged. I have the stuff to do it!!!!
Carl
Carl
LnrB's AC Refrigerant Lines
As promised, Dave, starting with the compressor:
The outboard hose you see there with the cap on, Low pressure I think, runs from the compressor to the firewall.
At the firewall is connection with the evaporator. The other fitting, just Inboard and in shadow here, holds the expansion valve and a much smaller line.
The small line is zip-tied to the Right strut and travels to the drier.
From the drier to the condenser.
Back to the compressor:
The other hose curls around under the compressor to the Left side of the condenser.
I can't say if this is technically correct but I can tell you It Works!
Randy, Darren, Elinor, Carl, thank you so much. From your posts I can see what the routing path is now. I am probably going to have to have more than one hose made, the only thing I got from the donor car was the dual hose manifold leaving the back of the compressor. I have nothing from the Jaguar (except the evaporator, of course). It looks like the only thing I will have to find a home for is the receiver/dryer (accumulator?). Elinor, my compressor is on the right side of the engine and at the very bottom of the heap. That makes it convenient for.........nah, I'm just kidding.
Darren, I am using the Camaro condenser/radiator/electric fans combo also. My plan is to control the A/C with the Jaguar system, just as the original was. I have yet to sort out all I think I know about the safety switch(s), but I'll get there.
Carl, sorry to hear of your experience. Now that I have an idea where the hoses should run to, I can start figuring out a route. With your experience, where would the better route for the hoses be? I have just finished moving the PCM for the 4th time, now that I have the engine in place. Sometimes it just doesn't pay to get ahead of yourself.
Again, thank you all.
Dave
Dave
Dave,
finaly got the pics for ya, placement of the accumulator in mine was determined by the factory hard line that comes off of condenser . As shown in pic, then another section of factory hard line with pressure switch( that doesn’t work like an old fashioned one) comes from other side of accumulator and gets connected to a custom made line to go to evaporator. Factory dual line manifold high side. Still reached condenser with no issues, low side gets end cut off and a gets additional hose to reach the evap
Accumulator placement
Low side From compressor manifold
Factory hard line. With trinary switch
orator
orator
Darren and Roger, thanks for your pictures, very helpful. One thing I notice in your pics that I don't see in Elinor's is the nipple w/electrical fitting on the small GM factory hose and the nipple on the large GM factory hose. Would the electrical fitting be the "A/C pressure sensor", I have wires in the Jaguar harness that are identified as such. Roger, in your first pic, you have spliced onto the large hose and there is a port or maybe a schrader valve between. What is the purpose there? I'm not using any part of the Jaguar A/C system except the expansion valve and evaporator, everything else is LT1 or '97 Camaro.
I can see another move in my future, the drier should go where I've put the radiator over-flow tank. No problem.
Thank you both very much.
Dave
Dave
LT1 jaguar (05-16-2021)
Roger,
do you know how much Freon (r134a)you put in? I couldn’t find anything being as system is hybrid from 2 cars, I just used the cans with built in gauges and watched the gauge, stored adding when the gauge was in middle of full range, not an exact science by a long shot, but it got me cooling!
Thanks Roger, I've run across the terms "accumulator" and "receiver/dryer" in my research. What I came away with is an accumulator is used in a system with "orifice metering" and a receiver/dryer is used in a system with an "expansion valve". Since I have replaced the expansion valve on the fire-wall, that means I will need to use a receiver/dryer?! How did you connect the high pressure switch (on small hose) to the Jaguar wiring?
Dave
Dave
All the info I have left on this car.
Dave
I added the '73 Jag electrical so you can see what I was dealing with on this car.
The three relays on the left are for the fan(s) and the other is for the compressor.
Relay wiring:
Wire from Ranco switch to pin 86
Ground to Pin 85
12 Volts to pin 87
Compressor to Pin 30
Other side of compressor to ground
You can reverse the connections to pin 87 and pin 30 if you want. With ignition on, turning up the Ranco for max cooling should pull in the
relay, which should pull in the compressor clutch.
Relay wiring:
Ground to Pin 85
12 Volts to pin 87
