Can anyone help identify this part?
Hi all!
Recently been having some issues such as consistently losing coolant with no puddles, white smoke, milky oil, etc etc,
anyways the current hope is that its simply a blown head gasket and not a cracked block, (I own an 86 Xj6 which If my information is correct is a year in which they did not use the horizontal coolant passages in the block that are notorious for cracking)
anyways ive gotten around to disconnecting the exhaust and after looking behind th exhaust manifold I saw a part I was unfamiliar with.
any info on it or if it needs to be replaced would be great, ill attach a pic below.
(there are two other circular spots but with what looks like either very very tightly fitted plugs or just metal attached to the head itself inside)
Received 9,472 Likes
Received 10,989 Likes
The following 2 users liked this post by Doug:
LT1 jaguar (04-23-2023),
motorcarman (04-23-2023)
