Can I get to dash gauges by taking top dash pad off?
That's the question. Getting ready to pull the gauges out again to put in LEDs and change the bezels to chrome. My old finger joints are getting a bit stiff and it's pretty hard to reach in the big holes and get a good enough grip on the knurled knobs to get the little gauges out.
Top dash pad is described as pretty easy to take off. Set of screws on the end caps and a row of screws under the pad along the dash board. Would that make it easier to access the gauges?
Thanks,
Mark
Thanks,
Mark
Received 9,204 Likes
in the Series 3 XJ, you can push-in and then turn the speedo and tach clockwise or counterclockwise to remove them, but you cannot get to the other gauges by removing the dash cap.
once you remove the speedo and tach, you can get your hand through the holes and reach the rear of the other gauges, and using a mirror in one hand and flashlight in the other, ascertain which is the bulb holder that you need to pull out.
I need to fully remove the gauges as I am not only replacing the bulbs but will be changing the bezels from black to chrome.
So Jose - are you saying that if I remove the dash top on my 1985 VDP I will not be able to access the backs of the gauges thru the top? Is there a metal fascia under the dash pad that would block access?
Thanks,
Mark
exactly, there is a metal "beam" at the top of the wood dash, which is covered by the dash pad, and behind that beam, you have the a/c ducting "boxes" and vacuum actuators, which don't let you get your hands down towards the gauges, but go ahead and give it a try, the only caveat is that it is very easy to affect the vacuum lines and then you might end up with another problem.
I would suggest there is better access from below the dash, removing the panel under the steering column, but it would still be a tight fit getting your hand upwards.
Bhoyceltic
US Southwest
09-03-2015 09:11 AM
