Can a series II engine work in a Ser III?
Old 04-25-2014, 09:37 PM
Calhale's Avatar
Default Can a series II engine work in a Ser III?
Seems simple enough -- I have a line on a ser 2 engine just rebuilt for a very, very reasonable price, and I'm still waiting on WD 40 to work it's magic on the the head of my ser 3.
I'm curious if the switch out is possible -- it would be a ser 2 from about 1972, and a ser 3 from 85, so a move would involve replacing the carbs with fuel injection to start. Anything else?
Old 04-26-2014, 04:52 AM
Received 10,507 Likes on 6,939 Posts
Technically it should be OK with the EFI system installed.
Bear in mind that the S3 engines had larger inlet valves to compliment the EFI addition, BUT, most people rebuilding the older small valve heads put the larger inlets in.
The cam profiles I think?? are the same.
The S3 oil filter housing will be needed.
The breather snout at the head front will need to be the S3 unit.
After that I see nothing else that should trip you over.
Old 04-27-2014, 06:44 AM
Calhale's Avatar
Thanks.
adenshillito
02-17-2016 07:05 AM
johnnie ryall
10-19-2015 09:44 PM
thedugger1
09-24-2015 05:32 PM
ogorir
09-03-2015 07:34 PM
SingBlueSilver
08-27-2015 02:20 PM
Quick Reply: Can a series II engine work in a Ser III?
