Car stalls as soon as I take off
Series 3 1983 4.2 van der plas. it starts and idles OK when go to take of it has no power, has new fuel regulator, new brake booster diafragm, checked the fuel pressure, had injectors cleaned, new fuel pump and coil, checked everything for air leaks, AFM been checked, new plugs, all sparking ok, a diode replaced i the middle electric block on the firewall, fuel tanks been cleaned out. Any ideas?
Received 10,989 Likes
The thread title says “stalls”…. which I would interpret as the engine stops running.
“No power” implies the engine stays running.
Please clarify exactly what’s happening.
If the engine stays running but the car won’t move then Jose’s advice to check the transmission fluid is your best next step.
Received 1,096 Likes
The following 2 users liked this post by Bill Mac:
Greg in France (05-25-2022),
yachtmanbuttson (05-25-2022)
Finally, the coolant temperature sensor may be faulty - if so, the engine will not be receiving the “enrichment” needed during the warm-up period, and this results in stalling. “Been there and done that “. The sensor is not expensive and is very easily replaced - and it is easily accessible on the engine.
I second the fuel filter! I had similar issues ( but inhave smaller inline filters before the change over valve, and car would bog down and sometimes backfire through the intake ( and then blow bellows off of throttle body) but only using right tank! My suggestion it to replace fuel filter and add two smaller inline ones before the valve! Fixed all my problems
stalls
yes it stops running, have replaced coolant sensor as well and the fuel filter, trans fluid is OK as well, mechanic changed to another AFM 500 kms ago and was OK tho could have gone wrong since, could the idle mixture screw cause this?
