Car Won't Crank When Hot
Hello,
We have recently detected another issue with the XJ6 - S3
The problem with the car is when the engine gets hot and the ignition is turned off, the car never starts unless the engine cools down.
What might be the possible issue now and how do i get it fixed?
Mike
Mike
Received 2,399 Likes
Hi Mikega,
Please clarify 'won't crank'
The engine literally won't crank over, or
engine cranks over but won't ignite (start).
As JagCad say's, if it won't crank then there is most definitely an electrical issue.
If it cranks over, but doesn't start when hot, then other factors come into play, like
weeping fuel injectors
Faulty coil / amplifier
Bung Temp Sensor
A longer shot - wiring harness flaky
More specific info, more specific diagnosis.
Cheers,
Nigel
Bung Temp Sensor
Cheers,
Nigel
Received 10,944 Likes
Mike has two postings on the same issue. He has a true 'no crank' problem. That is, the starter does not operate
The (what should be) common terminology to differentiate is "No crank, no start" and "Cranks but won't start"
Engine Will Not Crank Checklist
sjwalk
08-08-2012 02:21 PM
GT42R
07-06-2012 06:44 PM
