Cat Converter
Legaly, No.
You may do so and get away with it, but that depends on your states inspections, both emissions and visual. But it is a Federal violation to remove it.
There are "Euro downpipes" that mount to the manifold to solve that problem, but then you have the oxygen sensor to contend with.
There are probably two catalytic converters on your car, BTW...
David
EverydayXJ.com
David
EverydayXJ.com
I'm not certain of the effect totally removing the oxygen sensor would have. Quoting from the service manual, "the sensor monitors the oxygen content in the exhaust and sends a proportional signal to the ECU, maintaining close air/fuel ratio control under all operating conditions".
Maybe Doug or JTO will let us know how that would effect the ECU.
Here is a photo of a setup similar to the Euro downpipes. Just a pipe coming off each exhaust manifold, and joining into a single pipe. The ones that I've seen on most modified Federal cars have been machined to accept the oxygen sensor.
David
EverydayXJ.com
David
EverydayXJ.com
Aus V8S
11-13-2015 11:01 AM
02jagstype
09-04-2015 08:20 PM
rachelstr
09-03-2015 12:59 PM
