Centering front caliper; where to measure
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
I am having difficulty with my front calipers after installing S/S pistons as they are no longer centered about the rotor. I am confused on what to use as a measurement point on the caliper. Should I use the flat areas on the caliper body that the rotor rides between, or should I use the outward face of the pistons? Thanks in advance!
Maybe I have missed something over the years, dunno.
The calipers bolt up to the vertical strut, on the 2 ears cast and machined from the factory, thats it.
There is no adjustment for rotor position.
I have never had issues on any of mine, and those items have been off and on so many times.
The shims in that area are for the steering arm, and have nothing to do with the caliper.
Received 2,263 Likes
No, it is a fixed caliper, not a floating caliper. That is why it needs to be adjusted to center it.
Machining stuff or adding shims is a case of two wrongs don't make a right.
Is the caliper centred without the pistons installed? If no, find out why.
BUGGA.
Its a Series 3 E TYPE.
Sorry, my answer is probably not related to that brake system.
However, in the ONE only I have seen is pieces, they are a caliper similar to the Series XJ fixed style, which means, as already stated, the pistons are not retracting into the caliper far enough, maybe coz they are for the XJ caliper, and not the E caliper, dunno.
So, the pistons are not retracting adequately either due to a manufacturing error or poor design. Ditch them and use OEM stuff.
