Chevy TPI to 1971 jaguar XJ6 help.!!
HELLO FAMILIA JAGUAR!!
I am new to this site, so fas so good, very informative, great help overall.
I need help wiring the Chevy TPI to the wiring on the 1971 Jaguar XJ6. Can some help me or point me in the right direction?
thank you all in advance
First wash in about 2 years
Working on air suspension
I'm a TPI expert. Looks like you've got a 89+ speed density TPI system. I'd recommend a Painless Performance 60103 and the right GM ECM. In this case the ECM is a 1227730. You can use a V6 1227730 which are far less expensive. Then you'll need to send the PROM module to someone like me to have it converted to V8, have the VATS removed and the program optimized for you setup, (transmission, gear ratio, TCC function, speedometer calibration, etc)
TPI is a great match for these cars, all the torque makes for a good driving experience if they are setup properly.
If you have the original harness, I have all the wiring diagrams of what to connect to where, if you go the painless harness route then I doubt they will be any good, unless wires are same colour etc
but my diagrams are more for a series 3, with a high pressure fuel pump etc
Shotcaller0074
07-31-2022 06:31 AM
pricebill
02-05-2020 12:42 AM
FS[Western US]: 1971 Jaguar XJ6 Sedan Complete Dash & Front Seats
Giovanni LiCalsi
05-22-2015 06:02 PM
vdubluv74
03-17-2015 06:37 PM
