Cigar(ette) lighter
Cigar(ette) lighter
Okay, I spent some time cleaning up some of the electrical stuff that had been band-aid-ed over several times. I finally got a new stereo, w/ Bluetooth, installed and working. But somehow, the power to both lighters (front dash and rear console) got disconnected. As far as I can tell, everything else works - all the other dash accessories. And all fuses are good.
The question, obviously, is how to get them working, without having to take too much apart.
Any ideas?
TIA
ken
Any ideas?
TIA
ken
the rear lighter is powered from a harness that runs on the right side of the center console and connects to a fused wire. you might be able to pull the fuse socket inserting hand under right bottom edge of center console. If not, shifter, ashtrays, and switches panel must come off. Sometimes the fuse is behind the left knee panel, passenger side in LHD cars.
Received 10,873 Likes
Received 9,213 Likes
JaguarXKR
04-08-2013 11:58 AM
